Concatenate all data tables using JSL
Hi, I want to concatenate all open data tables. However, the number of data tables can vary and I want the script to be able to adapt for different number of tables.
This is the code for what I want to do, however I want to have it generalised:
Data Table(N Table()) << Concatenate(
	Data Table((N Table() - 1)),
	Data Table((N Table() - 2)),
	Data Table((N Table() - 3)),
	Data Table((N Table() - 4)),
	Data Table((N Table() - 5)),
	Output Table("All Temps"),
	Create source column
This is code I have tried, an error of unresolved name of output table occurs ( in this case noTemps is 6 )
	For(i = 1, i < (noTemps), i++,
		Data Table((N Table() - i)),
	Output Table("All Temps");,
Re: Concatenate all data tables using JSL
If JMP16+ I would use for each and loop over the list of tables
dt1 = Open("$SAMPLE_DATA/Big Class.jmp");
dt2 = dt1 << Subset(All Rows, Selected Columns(0), Output Table("DEMO"));
dts = Get Data Table List();
dt_first = Remove From(dts, 1); // remove first table as we concatenate to that
For Each({dt}, dts,
	dt_first << Concatenate(
		dt,
		"Append to first table",
		"Create source column"
	// Close(dt, no save);
Which version of JMP are you using?
For Each({dt}, dts,
		dt,
Thank you for your response, however I'm struggling to make this apply to my situation (although I think it should be relatively easy).
What is dt? I get a name unresolved error.
I also don't have dt1 assigned as all the tables are already open from the previous part of the script. How can I assign it without directly calling a specific table?
If I do assign dt1 like below a demo table is produced however, the table is full of the word demo.
dt1 = Open( "$DOCUMENTS/Plot_Conduction_Losses/Module 6/DUT2/100C.jmp" );
Sorry if this is poorly explained and wordy.
dt1 and dt2 are there just for demonstration purposes. You get the references to all open tables using Get Data Table List(). Which JMP version are you using (For each requires JMP16+, but it can be replaced with For)? dt is reference to a data table which can be found from the list of datatable referenes in dts.
I have JMP 17.
I understand the dt part now, sorry for the confusion.
Thank you for your help
Didn't remember you can use a list with concatenate
Open("$SAMPLE_DATA/Students.jmp");
Open("$SAMPLE_DATA/Students1.jmp");
Open("$SAMPLE_DATA/Students2.jmp");
dt_first = Remove From(dts, 1)[1]; // remove first table as we concatenate to that
dt_result = dt_first << Concatenate(dts, "Create source column");
Also have to/should get first index from Remove From() because Remove From() returns a lists.
