BookmarkSubscribeRSS Feed
mad
Jun 23, 2011
Concatenate Multiple Data Tables [SOLVED]
I have 605 data files I need to concatenate after filtering out the data I don't need from each file. Looping through each file, deleting the rows I don't need, concatenating the current file to the first file, then closing the current file works fine for the first 10+ files but gets exponentially slower with each additional file. Any suggestions?
I have noticed that each time a file is concatenated the source script gets added to the data table, could this be what is slowing things down? Is there a way to prevent this or delete them?
Message was edited by: MAD
mad
Jun 23, 2011
Re: Concatenate Multiple Data Tables [SOLVED]
Each time a file is opened and after each concatenation operation add:
dt << Delete Table Property( "Source" );
This dramatically improved the speed.
chungwei
Jun 23, 2011
what version of JMP are you running ?
mad
Jun 23, 2011
JMP 8.0
chungwei
Jun 23, 2011
I think this was fixed in 8.0.1.
mad
Jun 23, 2011
You are correct. I installed the 8.0.2 update and removed my workaround. It works fine. Thank you for pointing me to the update.
