dkraeuter_sunne
Component Count Incrementing
I have data where a certain number of parts are used on a component before it is replaced. At the point when the component is replaced, the part count is reset to 1. I would like to create a column that increments the component count each time the part count is reset to 1. How would I do this?
I attached a picture of the part count over time to help with understanding how the data looks.Time vs Part Count.JPG
dkraeuter_sunne
Re: Component Count Incrementing
If( Row() == 1,
	x = 1,
	If( :Part Count == 1,
		x++,
		x
x;
This will be very easy to do, if you can tell me what is the indicator that the Component has replaced?
dkraeuter_sunne
The indicator that the component has been replaced is when the part count reverts to 1.
Is this what you needed?
Here is a formula that will work
If( :Part Count == 1 | Row() == 1,
	x = 1,
	x
x;
ThuongLe
It's quite simple. The steps are this:
  1. Sort Time column ascending
  2. Create new column "ComponentCount" with below formula:
New Column("ComponentCount", Numeric, Continuous, Formula(
      If(Row() == 1, 0,
         :PartCount == 1, Lag(:ComponentCount, 1) + 1
dkraeuter_sunne
If( Row() == 1,
	x = 1,
		x++,
		x
x;
