csf
csf
Comparing New Design to Baseline Design - How do I set this up to see valuable information.
I have two sets of data Baseline standard Temp (completed 3x) and Baseline Aged (completed 3x).
I also have New design standard  and new design aged (completed 3x each)
The longer T (time) is the better
 Test 1test 2test 3
Baseline standard Tempt1t2t3
New design  standard Tempt4t4t6
Baseline Agedt7t8t9
New design agedt10t11t12
How do i set this up to see:
  1. how the new design performs in standard vs baseline.
  2. How aged affected baseline
  3. How aged affected new design
Thank you in advance.
statman
Re: Comparing New Design to Baseline Design - How do I set this up to see valuable information.
Enter your data into a JMP file (example attached).  From there you can do the tests you'd like.  You have a factorial of Baseline and New with 3 repeats per treatment.
