BookmarkSubscribeRSS Feed
sanqub
Jan 11, 2016
Compare results simulation and experimental
Dear All
I want to compare my experimental and simulation results. Is there any graph/feature in JMP which allows me to compare and represent them pictorially.
Thanks in anticipation.
ian_jmp
Jun 23, 2011
Re: Compare results simulation and experimental
There may be many ways to do this, depending on the variable(s) that make up your simulated and experimental results. Perhaps you could give a list of column names and types (numeric or categorical) in each set?
sanqub
Jan 11, 2016
Could you please direct me to an example or discussion to give a clear idea.
My study consists of four inputs and one output. I have experimental and simulation data.
So any graph feature can be used like contour or surface etc. ?
