AY
AY
Combine multiple jmp datatable into single excel file
Hi, is there any way to combine multiple jmp data table into a single excel file but with multiple sheets?
Means, i have dt1 and dt2, but i want to combine both of this in same data.xlsx. So, inside data.xlsx, there will be two sheets which are sheet1 is dt1 and sheet2 is dt2.
By the way, i am using JMP Pro version 11.1.1
Re: Combine multiple jmp datatable into single excel file
There is a feature called "Create Excel Workbook" that will do exactly what you need.  However, you will need JMP 13+ to do it.
Brian Corcoran
JMP Development
Brian Corcoran
JMP Development
