You can easily convert all 3 of your columns into proper Date/Time columns for "Date hour preparation" and "date hour use" and into a duration column for the column called "Difference".
I will start with the column "Difference"
1. Right click on the column header for column "Difference" and choose "Column Info". You will see the following screen
2. Change the Data Type to Numeric. (A New format field will be displayed)
3. Change the Modeling Type to Coninuous
4. Change the Format to
Duration==>hr:m
The window will now look like
5. Click on the "Apply" button and the Difference Column will be changed to Numeric/Continuous
You can repeat the above steps for the 2 date/time columns, but instead of selecting a Duration format, select
Time==>d/m/y h:m
Which results in a data table looking like
