JulieSAppel
Column switcher & try function
Is it possible to use the try function in a column switcher script? I´m creating a script where I add a column switcher fore a few chosen columns to a graph which works fine. However, sometimes a column will be missing which will make the script stop. Therefore, I´m trying to use the try function for each of the relevant columns (as I don´t want all columns in the column switcher) but I can´t make it work.
dt << Column Switcher(
	Try( (:RER), Throw( "RER does not exist" ) ),
	Try( (:VO2), Throw( "VO2 does not exist" ) ),
	Try( :Name( "Drink-[ml]" ), Throw( "Drink-[ml] does not exist" ) )
Is it possible or is there a better way to do this?
Br Julie
Re: Column switcher & try function
Here is how I would do it
// set desired list of columns to be in column switcher
desiredColList = {"Height", "Weight", "Zippy"};
// remove from list, columns that are not available
For( i = N Items( desiredColList ), i >= 1, i--,
	If( Try( Column( dt, desiredColList[i] ) << get name, "" ) == "",
		Remove From( desiredColList, i, 1 )
// If columns are available, run the platform
If( N Items( desiredColList ) > 0,
	ow = oneway( x( :age ), y( :height ) );
	ow << Column Switcher( :height, desiredColList );
I would use the Try() function outside of the message. Build the message conditionally. Like this:
Names Default to Here( 1 );
dt = Open( "$SAMPLE_DATA/Fitness.jmp" );
gb = dt << Graph Builder(
	Size( 532, 456 ),
	Show Control Panel( 0 ),
	Show Legend( 0 ),
	Variables( X( :Age ), Y( :Oxy ) ),
	Elements( Points( X, Y, Legend( 3 ) ) )
alt cols = List();
Try(
	Insert Into( alt cols, Column( dt, "Age" ) )
Try(
	Insert Into( alt cols, Column( dt, "Weight" ) )
Try(
	Insert Into( alt cols, Column( dt, "Runtime" ) )
col switcher expr = Expr( Column Switcher( :age ) );
Insert Into( col switcher expr, alt cols );
Eval(
	Insert(
		Expr( Send( gb ) ),
		Name Expr( col switcher expr )
