BookmarkSubscribeRSS Feed
DSA
DSA
Community Trekker
Column switcher & callback scripts?
Hey JMP community,
I have a control chart with a column switcher, and I would like to update a reference line in the control chart when the column in the switcher is changed, but I cannot find an action on the column switcher object that seems to be able to to that. All the actions i get in showproperties() are related to changing the values via JSL.
Any suggestions? :)
Thanks in advance,
Daniel
Re: Column switcher & callback scripts?
Frame Box() is where you will find such call backs.  You can
     << Add Graphic Script
to the Frame Box(), which is triggered anytime something changes in the chart
biv = Bivariate(
	Y( :weight ),
	X( :height ),
	FitLine
rbiv = biv << report;
framebox = rbiv[frame box( 1 )];
framebox <<
Add Graphics Script(
	Transparency( 0.5 );
	Fill Color( {1.0, 0.5, 0.0} );
	Polygon( [60, 72, 57], [75, 120, 120] );
biv = Bivariate(
	Y( :weight ),
	X( :height ),
	FitLine
framebox <<
DSA
DSA
Community Trekker
Thank you for a very quick and accurate reply Jim,
it works flawlessly!
/Daniel
DSA
DSA
Community Trekker
Hmm, now when I have played a bit with it it does seem like the script is launched always, over and over, and not only on changes in the graph.
It is basically killing JMP by updating this reference line over and over...
rep2 = cc2 << Report;
rep2[FrameBox(2)]<<Add Graphics Script( SCRIPT );
I am running JMP 13.2.0
I have run into your observed issue, and overcome it by putting into the Grapics Script my own logic to only update when the script detects the change conditions I want to trigger on.
DSA
DSA
Community Trekker
Thanks for the reply.
I've managed to implement a trigger as you suggested and it works much better now.
Thanks,
Daniel
