Column reference and sort/Stack
vishwasanj
Dec 27, 2016
Hi All,
I have been working on this dilemma for a while.
I have a data table and I need to sort series of columns in ascending order which comes after a specific column (Col_Y),
jdt=kdt << Sort(
By( :Name( "0 0" ), :Name( "168H 85C" ), :Name( "504H 85C" ) ), // These columns vary from 2 to 5 or more..
Order( Ascending, Ascending, Ascending )
// I do some color coding in the middle
After sorting, I need to stack them up,
edt=jdt<< Stack(
columns( :Name( "0 0" ), :Name( "168H 85C" ), :Name( "504H 85C" ) ),
Source Label Column( "Label_bh_bt" ),
Stacked Data Column( "Data_bh_bt" )
My problem is I cannot use this in the code since the numbers and column keeps varying.
I understand how to get the reference of a column by
list = kdt << get column reference();
position = Contains( list, Column( "Col_Y" ) );
How do I move my reference pointer  to the next column and probably sort/stack them till I hit empty{} ?
I really appreciate your help.
Thank you.
Jun 22, 2012
Solution
See if this helps you out
// Create a sample data table
dt = New Table( "Subset of semiconductor capability",
	Add Rows( 10 ),
	New Column( "Col_Y1",
		Numeric,
		"Continuous",
		Format( "Best", 10 ),
		Set Property(
			"Spec Limits",
			{LSL( 104.412948990151 ), USL( 131.893493064355 ), Target( 118.153221027253 )}
		Set Values(
			[114.555760105678, 120.043693059459, 114.926510466106, 111.756445551183, 111.545085144313,
			113.52359591958, 111.749308571209, 114.411433304976, 118.48975048042, 113.171122695149]
	New Column( "PNP1",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
			{LSL( 164.389518443879 ), USL( 429.64634592871 ), Target( 297.017932186294 )}
		Set Values(
			[322.616751775796, 333.128079728678, 348.978757216574, 268.548094462492, 295.073165929223,
			323.833298568833, 369.320490694357, 342.987400315929, 315.52243608245, 288.978183718528]
	New Column( "PNP2",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
			{LSL( -136.122122529984 ), USL( 1067.00612015088 ), Target( 465.441998810449 )}
		Set Values(
			[469.390289765043, 437.781112798903, 532.12814730405, 373.058628529111, 338.900737368942,
			469.992171436316, 563.084459366587, 479.378108668814, 530.265608347575, 421.454501563007]
	New Column( "Col_Y2",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
			{LSL( 96.5938056459265 ), USL( 130.90419774122 ), Target( 113.749001693573 )}
		Set Values(
			[115.958473043434, 120.974137316372, 117.75312418797, 114.092607737274, 113.778098130642,
			116.488049497674, 115.935283026742, 115.762801088796, 116.347793739608, 116.232907922575]
	New Column( "PNP3",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
			{LSL( 118.677820430348 ), USL( 141.901766142544 ), Target( 130.289793286446 )}
		Set Values(
			[130.378809500886, 132.736937590235, 136.831952164704, 136.969154239163, 136.622623419893,
			137.480356512481, 138.094011176166, 142.10586919757, 134.750041237898, 129.719685093372]
	New Column( "IVP1",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
			{LSL( 59.6200689219354 ), USL( 67.2001519300058 ), Target( 63.4101104259706 )}
		Set Values(
			[73.4842940932646, 75.6074915248983, 73.3304733114595, 75.7647427124531, 70.5460961797334,
			72.9451281758323, 75.6756511920958, 76.4874855218512, 66.4572544989587, 72.2503891181424]
	New Column( "PNP4",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
			{LSL( -54.4319216800649 ), USL( 531.90910950445 ), Target( 238.738593912193 )}
		Set Values(
			[262.351408960942, 269.950148249765, 273.273874690651, 236.935577128975, 244.380589490586,
			267.186035095484, 290.774763825391, 282.589770870314, 258.238866835766, 241.25222968008]
	New Column( "NPN3",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
			{LSL( 97.317681821994 ), USL( 144.291664077077 ), Target( 120.804672949535 )}
		Set Values(
			[119.47852252254, 122.25499204522, 120.033132204358, 116.970066814936, 116.214953853587,
			120.041044282935, 115.572158051301, 118.992345590077, 120.928324071462, 117.320359424529]
	New Column( "Col_Y3",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
			{LSL( 139.200434284046 ), USL( 145.409947550315 ), Target( 142.305190917181 )}
		Set Values(
			[139.588801950955, 144.633487927042, 136.369288337148, 146.477383476889, 132.328519479399,
			138.566660436878, 151.03999258707, 145.856209565548, 131.365614418469, 134.152985449894]
	New Column( "NPN4",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
			{LSL( 95.8856688269302 ), USL( 115.889615922419 ), Target( 105.887642374674 )}
		Set Values(
			[105.329761343596, 110.633367329871, 105.708502147323, 103.569269019798, 103.578483185784,
			104.373287001171, 105.263629156484, 104.884528151328, 106.703804152221, 105.664627560655]
	New Column( "SIT1",
		Numeric,
		"Continuous",
		Set Property( "Spec Limits", {LSL( 145.48315 ), USL( 185.72141 ), Target( 165.60228 )} ),
		Set Values(
			[148.807936826583, 152.591832248891, 154.568333571174, 118.695148858091, 137.736892539345,
			162.26978689599, 174.520277278376, 138.985120782571, 152.119109194528, 172.00040324347]
	New Column( "INM1",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
			{LSL( 57.0276784418165 ), USL( 99.0010932081266 ), Target( 78.0143858249716 )}
		Set Values(
			[77.1728296444077, 82.0469082410668, 83.687085328962, 80.7577994209762, 77.3810009438902,
			86.5969854076827, 83.9227125706495, 84.0696675266069, 75.8130299795504, 80.9676937912243]
	New Column( "INM2",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
			{LSL( 63.8010373764921 ), USL( 65.1798987027106 ), Target( 64.4904680396014 )}
		Set Values(
			[63.5204508646779, 63.3088610076463, 63.867818710853, 62.7780229155406, 59.203474982935,
			65.6340594039682, 68.2292406778111, 64.6692277412529, 62.6014259723118, 68.7977074923828]
	New Column( "VPM1",
		Numeric,
		"Continuous",
		Set Property( "Spec Limits", {LSL( -80.0000000000001 ), USL( -80 ), Target( -80 )} ),
		Set Values( [-80, -80, -80, -80, -80, -80, -80, -80, -80, -80] )
// Here is the actual code
// Create a list of the Y columns to be found
YColList = {"Col_Y1", "Col_Y2", "Col_Y3"};
// Get all of the columns in the data table
AllColList = dt << get column names( string );
// Loop across the list of Y columns and sort and stack
For( I = 1, I <= N Items( YColList ), i++,
	startCol = Contains( AllColList, YColList[i] ) + 1;
	If( i == N Items( YColList ),
		endCol = N Col( dt ),
		endCol = Contains( AllColList, Char( YColList[i + 1] ) ) - 1
	targetList = {};
	For( t = startCol, t <= endCol, t++,
		Insert Into( targetList, AllColList[t] )
	jdt = dt << Sort( By( Eval List( targetList ) ) );
	edt = jdt << Stack(
		columns( Eval List( targetList ) ),
Jun 22, 2012
Solution
	Add Rows( 10 ),
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column( "PNP1",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column( "PNP2",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column( "PNP3",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column( "IVP1",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column( "PNP4",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column( "NPN3",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column( "NPN4",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column( "SIT1",
		Numeric,
		"Continuous",
		Set Values(
	New Column( "INM1",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column( "INM2",
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column( "VPM1",
		Numeric,
		"Continuous",
	targetList = {};
	edt = jdt << Stack(
vishwasanj
Dec 27, 2016
That was perfect. Thank you txnelson :)
