BookmarkSubscribeRSS Feed
vkessler
Community Trekker
Column name is not shown in graph builder
Hello everybody,
i named some columns in a table like this:
Foo-Bar
Bar-Foo
Rsh (Ohm)
So the name is a bit long and split over 3 lines.
Now, when i want to make a graph with graph builder, i see this:
The name of the designated columns do not show up fully in the variables menu. I can only see the "Rsh" - no "Foo", no "Bar".
Is there a possibility to actually show at least a litte bit more of the name, or even the full name?
Thank you!
Jeff_Perkinson
Re: Column name is not shown in graph builder
Sorry about this. It looks like a bug.
Please send a sample of your data table that reproduces the problem to Tech Support. They'll investigate and give you a workaround if there is one.
-Jeff
-Jeff
vkessler
Community Trekker
Thank you for your reply. I mailed the problem with an example to suppot.
-Victor
