maswan
Column name as expression inside loop doesn't work
Hello Community,
I am trying to automatize the generation of some graphs making a loop over some columns of my graph.
For example, my Column's names are: H_1 , H_2 ... H_12
I tried
x1_ = Expr( Y( Expr( ":H_" || Char( iAus ) ) ) );
I also tried
x1_ = Expr( Y( Column( Expr( "H_" || Char( iAus ) ) ) );
and also:
x1_ = Expr( Y( As Column( Expr( "H_" || Char( iAus ) ) ) );
and inside the iAus loop
Variables( X( :Tag ), Eval( Eval Expr( x1_ ) ), Group X( :NAT ) ),
didn't work out. --> Error = Specified Column not found in data table. in access or evaluation of 'Eval' , Eval/*###*/(Eval Expr( x1_ ))
I needed to use the column number rather than using an expression, like this:
Variables( X( :Tag ), Y( As Column( 26 + iAus ) ), Group X( :NAT ) ),
In another part of my script I got it right:
x1 = Expr( "H_" || Char( iAus ) );
and inside the iAus loop:
Dispatch(
Eval( Eval Expr( x1 ) ),
ScaleBox,
{Format( "Fixed Dec", 15, 1 ), Min( 0 ), Max( 1.4 ), Inc( 0.2 ), Minor Ticks( 1 ), Label Row( Set Font Size( 11 ) )}
Can someone help me and point out what I'm doing wrong?
Thank you in advance
pauldeen
Re: Column name as expression inside loop doesn't work
You cannot concatenate a string to an expression. Try the substitute or eval insert method.
Insert one expression into another using Eval Insert, Eval Expr, Parse, and Substitute
pauldeen
