jy06115197
Column formula help
Hello all,
How do I get the average value between row 3 and row 4 by using variables?
I was thinking of doing something like the following, but it did not work
Thank you and your reply is highly appreciated!
Re: Column formula help
I am sorry, but I do not completely understand what you are trying to do.  Hopefully, to continue the conversation, and to possibly give you some methodologies to review, I have some JSL below that creates a data table similar to your table, with 3 different formulas using different methods of calculating a mean.  Take a look at it, and see if it gets you what you want, or if not, then can you be more specific in exactly what you are trying to calculate.
New Table( "Example",
	Add Rows( 4 ),
	New Column( "Label",
		Character,
		"Nominal",
		Set Values( {"Dry", "Wet", "outlet Dry", "Outlet Wet"} )
	New Column( "a",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [80, 67, 57, 55] ),
		Set Display Width( 47 )
	New Column( "b",
		Numeric,
		"Continuous",
		Set Values( [79, 66, 59, 57] )
	New Column( "c",
		Numeric,
		"Continuous",
		Set Values( [88, 77, 66, 55] )
	New Column( "One",
		Numeric,
		"Continuous",
		Formula(
			dt = Current Data Table();
			Mean( dt[Row(), Index( 2, 4 )] );
	New Column( "two",
		Numeric,
		"Continuous",
		Formula(
			Mean( dt[Index( 3, 4 ), Index( 2, 4 )] );
	New Column( "three",
		Numeric,
		"Continuous",
		Formula(
			theColumns = dt << get column names( numeric );
			Remove From( theColumns, 4, 2 );
			Mean( theColumns );
	Add Rows( 4 ),
		Character,
		"Nominal",
	New Column( "a",
		Numeric,
		"Continuous",
	New Column( "b",
		Numeric,
		"Continuous",
	New Column( "c",
		Numeric,
		"Continuous",
	New Column( "One",
		Numeric,
		"Continuous",
		Formula(
	New Column( "two",
		Numeric,
		"Continuous",
		Formula(
		Numeric,
		"Continuous",
		Formula(
			Mean( theColumns );
jy06115197
Thank you so much!
