Paul_Mak_J
Column axis properties: save without hardcoding reference line so spec limit is always used.
I have a script that updates a dataset, used for plotting trend charts, and refernces a spec limit table which can be updated as needed.  I want to save the axis scale value for each related column property and even copy that scal to other columns as needed.  I don't want to save a the latest spec limits as a hardcoded value in the axis property per column.  Not sure how this is done using an interactive method.  would rather not script these preferences.
