BookmarkSubscribeRSS Feed
Column Properties
Kevinmdaly
New Contributor
Aug 1, 2017
I am Trying to set a column Properties from VBA. Specifically the Spec Limits Properties. When I create the column in vba i can acces its methods and properties but cant identify what propertity or method relates to the SPec Limits. Any help would be appreciated.
briancorcoran
Jun 23, 2011
Unfortunately, there is no automation interface to column properties.  For something like that, you would need to submit a piece of JSL code using something like "RunCommand" on the application object.  The JSL would have to reference the column by name, and then get/set the spec limits using the column reference that JSL returns.
Brian Corcoran
JMP Development
Kevinmdaly
New Contributor
Aug 1, 2017
Thank you, I think i can achieve my required endpoint by using template tables with pre configured colums and spec limits.
