BioMikey
Column Formula question
Easy qeustion for you all: I want to slightly modify a formula for selected rows, but there is no obvious way to do that, without changing the entire column formula. Any ideas?
Thanks,
BioMikey
Re: Column Formula question
There is only one formula expression for the entire column, but the expression can include conditionals that include various row-state flags:
Hope that helps!
Hope that helps!
BioMikey
That does help. Thank you!
