BookmarkSubscribe
aserino
Color cells for values that do not appear the most in each row
Hi all,
I've been struggling to put together something that works for this.
I'd like to iterate over each row and color the cells whose value appears NOT the most. For example, using the following table:
 RowNamesStore1Store2Store3Store4Store5
1AnimalCatDogCatCatBird
2Cost10128106
Row 1: highlight Dog and Bird
Row 2: highlight 12, 8, and 6
Thanks!
Re: Color cells for values that do not appear the most in each row
Here is a script that works for your example data table, and with a little work, should work for whatever tables you need it to work with
dt = New Table( "example",
	Add Rows( 2 ),
	New Column( "RowNames", Character( 16 ), "Nominal", Set Values( {"Animal", "Cost"} ) ),
	New Column( "Store1", Character( 16 ), "Nominal", Set Values( {"Cat", "10"} ) ),
	New Column( "Store2", Character( 16 ), "Nominal", Set Values( {"Dog", "12"} ) ),
	New Column( "Store3", Character( 16 ), "Nominal", Set Values( {"Cat", "8"} ) ),
	New Column( "Store4", Character( 16 ), "Nominal", Set Values( {"Cat", "10"} ) ),
	New Column( "Store5", Character( 16 ), "Nominal", Set Values( {"Bird", "6"} ) )
// Add a new column to use as a pointer to the row
dt << New Column( "TheRow", formula( Row() ) );
// Convert to static values for TheRow
dt:TheRow << delete formula;
// Stack the columns in question, so the processing can be done all at once
dtStack = dt << Stack(
	columns( :Store1, :Store2, :Store3, :Store4, :Store5 ),
	Source Label Column( "Label" ),
	Stacked Data Column( "Data" ),
	Name( "Non-stacked columns" )(Keep( :TheRow ))
// Summarize the data to find the max count for each row values
dtSum = dtStack << Summary(
	Group( :TheRow, :Data ),
	Freq( "None" ),
	Weight( "None" ),
	Link to Original Data Table( 0 )
Close( dtStack, nosave );
// Add a new column to represent the maximums
dtSum << New Column( "TheMax",
	formula( If( :N Rows == Col Maximum( :N Rows, :TheRow ), 1, 0 ) )
// Delete the non max rows in the table
dtSum << select where( :TheMax == 0 );
dtSum << delete rows;
// Create a new table that has only one row for each row in the original data table
// and has a column for each maximum value found
dtSplit = dtSum << Split(
	Split By( :Data ),
	Split( :Data ),
	Group( :TheRow ),
	Remaining Columns( Drop All ),
	Sort by Column Property
Close( dtSum, nosave );
// Add a column that concatenates all values into one
theColumns = dtSplit << get column names;
theColumns = Remove( theColumns, 1, 1 );
dtSplit << Combine Columns(
	delimiter( "," ),
	Columns( Eval( theColumns ) ),
	Column Name( "The Maximums" )
// Delete the nonessential columns
dtSplit << delete columns( theColumns );
// attach the found maximumns to the original data table
dt = dt << Update( With( dtSplit ), Match Columns( :TheRow = :TheRow ) );
Close( dtSplit, nosave );
// Color the cells
For( i = 1, i <= N Rows( dt ), i++,
	theList = As List( Words( dt:The Maximums[i], "," ) );
	If( N Rows( Loc( theList, dt:Store1[i] ) ) == 0,
		dt:Store1 << Color Cells( "Red", i )
	If( N Rows( Loc( theList, dt:Store2[i] ) ) == 0,
		dt:Store2 << Color Cells( "Red", i )
	If( N Rows( Loc( theList, dt:Store3[i] ) ) == 0,
		dt:Store3 << Color Cells( "Red", i )
	If( N Rows( Loc( theList, dt:Store4[i] ) ) == 0,
		dt:Store4 << Color Cells( "Red", i )
	If( N Rows( Loc( theList, dt:Store5[i] ) ) == 0,
		dt:Store5 << Color Cells( "Red", i )
// Cleanup
dt << delete columns( {"TheRow", "The Maximums"} );
	Add Rows( 2 ),
	Freq( "None" ),
	Weight( "None" ),
	Split By( :Data ),
	Split( :Data ),
	Group( :TheRow ),
	delimiter( "," ),
// Color the cells
// Cleanup
pmroz
Interesting problem.  I tried a different approach using transpose, which allows me to use column operations.
	Add Rows( 2 ),
dtt = dt << Transpose(
	Label( :RowNames ),
	Output Table( "Transpose of example" ),
	invisible
for (i = 1, i <= nrows(dt), i++,
	one_col = column(dt, "RowNames")[i];
	tab = dtt << Tabulate(
		Show Control Panel( 0 ),
		Add Table( Row Table( Grouping Columns( column(dtt, one_col) ) ) ),
		invisible
	dtb = tab << Make Into Data Table;
	dtb << sort(by(:N), replace table(1));
	nr = nrows(dtb);
// Get the maximum counted value
	max_value = column(dtb, one_col)[nr];
// Now back to the original table - highlight everything but the max value
	for (k = 2, k <= ncols(dt), k++,
		one_value = column(dt, k)[i];
		if (one_value != max_value,
			column(dt, k) << Color Cells( "Light Yellow", i );
	close(dtb, nosave);
close(dtt, nosave);
Nice approach!
I do see one issue, what if more than one selection....let's say, both Cat and Dog have the same number of occurrances......
That is why I did the splitting and the combining of columns......
aserino
Thanks! This works great!
