hogi
Level XIII
Collection of "funny" Jmp newbie questions
good to know:
- how to do this and that in Jmp?
- where Jmp is different from other programs
- where Jmp is different from Jmp (inconsistencies)
[More Topic Containers like this]
Topic additional info
Data Tables
Why is it not possible in Jmp:
- to define a formula for a specific cell?
- to select any 2 cells in a spreadsheet?
JMP is Not a Spreadsheet
Is there a tutorial how to "slice" matrices?
matrix[5::-1]
answer
NB: The indexing of matrices will be improved in a future version of Jmp
why new table()?  answer
why is there no dt << n rows()? answer
Why does add row add a row to a data table - but doesn't add the values? answer
Why are there different column names for data imported via Open and MFI? answer
Is there something in JMP like freeze pane in Excel?
lock Columns
 New Formula Column / Concatenate numeric values
New formula column / count strings
Graph Builder
Why do FitYbyX and GraphBuilder use different color codings?
answer
 When comes (collision free) Column Switcher 2.0?
wish:
Add new switcher called Role Switcher
GUI
Why is there no Select mode in the Local Data Filter - like the one from (global) Data Filter? wish:
Local Data Filter - don't disable the SELECT option
In the Join Tables Platform, what's the difference between
Update main table with data from second ta...
The submenus of my Jmp installation open to the left
- Where is the setting to move the submenus to t...
Why does Scripting Index/See also not list the function xyz ? you want more items to show up in see also ?
suggest them here:
Scripting Index and online Help: "see also"
43 REPLIES 43
hogi
Level XIII
Re: Collection of "funny" JSL newbie questions
Why can I copy & paste Data filter settings from one report to another one
- but not from a Filter View to a Report or from a Report to a Filter View?
Filter Views - copy and paste settings
hogi
Level XIII
For numeric values, JMP can count # of (non-missing) entries - and unique entries
For Characters, JMP can only count unique entries.
NOT: # of (non-missing) entries
Counting of strings more complicated than counting of number ?!?!?!?!
hogi
Level XIII
JMP can concatenate 1 String and 1 Number
... and it can concatenate 1 String and 2 Numbers:
but it is unable to concatenate 3 Numbers ?
why  ?!?!?!
hogi
Level XIII
Why is there no Platform in JMP to normalize Data "by subgroup".
-> as a workaround, please use https://marketplace.jmp.com/appdetails/Normalization+GUI
