BookmarkSubscribeRSS Feed
saitcopuroglu
Community Trekker
Sep 29, 2014
ColSum Function results to be placed only once per label
I have a calculation formula in Calculations column as:
Col Sum( :Revenue, :Lable )
The calculation is displayed as calculations, however, is there an oppurtunity to display the result only in the first row of each label (as displayed by the desired column) and the rest rows to be handled as missing data, which helps a lot for further calculations?
ms
Jun 23, 2011
Solution
Re: ColSum Function results to be placed only once per label
Try this:
If( Row() == Col Min( Row(), :Lable ), Col Sum( :Revenue, :Lable ))
Or consider using a summary table for further calculations.
1 REPLY
ms
Jun 23, 2011
Solution
Try this:
