David_Burnham
Col Functions and Row States
According to the release notes for version 15 of JMP:
The Col functions honor excluded rows through the Excluded(Row State()) function.
Col Maximum( :height, :sex, Excluded( Row State() ) );
However, this syntax doesn't seem to work.  Can anyone suggest the corect syntax?
-Dave
17 REPLIES 17
Re: Col Functions and Row States
I quickly tested and seemed that using only Excluded() seemed to work (I'm using 15.2.1).
David_Burnham
Thanks for letting me know.  That doesn't work with 15.1 - I'll try and do a comparison with 15.2.
-Dave
I'll add this very simple example here if anyone else comes around:
New Table("ExcludeColMax",
	Add Rows(6),
	Compress File When Saved(1),
	New Column("A",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([1, 10, 100, 2, 20, 200]),
		Set Display Width(46)
	New Column("B",
		Character,
		"Nominal",
		Set Values({"A", "A", "A", "B", "B", "B"})
	New Column("C",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Formula(Col Maximum(:A, :B, Excluded())),
		Set Display Width(65)
	Set Row States([0, 0, 6, 6, 6, 0])
David_Burnham
I've tested with v15.2 and the issue is the same.  Note the use case is using the function within a script, not within a column formula (not sure why I would want a column statistic in a row).
-Dave
Maybe honoring means in this case that the excluded is just additional byVar in column statistics formulas?
If you want maximum value of column without excluded values, could you use Summarize instead of Col Maximum? It seems to ignore excluded rows.
dt =New Table("ExcludeColMax",
	Add Rows(6),
	New Column("A",
		Numeric,
		"Continuous",
		Format("Best", 12),
	New Column("B",
		Character,
		"Nominal",
	New Column("C",
		Numeric,
		"Continuous",
		Format("Best", 12),
	Set Row States([0, 0, 6, 6, 0, 6])
Write("Looping col max:");
For Each Row(
	Show(Col Maximum(:A, :B, Excluded()))
Write("\!N\!NOnly col max:");
Show(Col Maximum(:A, :B, Excluded()));
Write("\!N\!NSummarize:");
Summarize(dt, exg = By(:B), exm = Max(:A));
Show(Eval List({exg, exm}));
Show(Max(exm));
David_Burnham
I can code a solution - my question was specifically about whether version 15 allowed it to be done solely using the column functions - that was the impression I got from the release notes.
-Dave
Dave,
Very confusing. I think this is a question for our friend Wendy.
ian_jmp
Level X
Interesting. A pre-release build of JMP 16 seems to get it right for r=1 and r=2, but not thereafter:
NamesDefaultToHere(1);
mw = J(NRow(dt), 2, .);
for(r=1, r<=NRow(dt), r++,
	Row() = r;
	RowState(Row()) = ExcludedState(1);
	mw[r,1] = ColMean(:weight, Excluded(RowState(Row())));
	mw[r,2] = ColMean(:weight, Excluded());
	RowState(Row()) = ExcludedState(0);
AsTable(mw);
dt << Distribution(
			Continuous Distribution(
				Column( :weight ),
				Quantiles( 0 ),
				Histogram( 0 ),
				Outlier Box Plot( 0 )
			Local Data Filter(
				Add Filter(
					columns( Transform Column( "Row", Nominal, Formula( Row() ) ) ),
					Where( Transform Column( "Row", Nominal, Formula( Row() ) ) == 1 ),
					Display(
						Transform Column( "Row", Nominal, Formula( Row() ) ),
						N Items( 15 ),
						Find( Set Text( "" ) )
David_Burnham
Working with Big Class (of course):
colmaximum(:height,excluded(rowstate()))
This is working.  But on one computer but not another.  Both running 15.1.0.
Now I am totally confused!
Screenshots on next post ...
-Dave
