I was able to reproduce your graph with a simple Stack and then a Graph Builder.
Names default to here(1);
dt = New Table( "Example",
Add Rows( 5 ),
New Column( "Sample",
Character,
"Nominal",
Set Values( {"A", "B", "C", "D", "E"} )
New Column( "Component 1",
Numeric,
"Continuous",
Format( "Percent", 7, 2 ),
Set Selected,
Set Values(
[0.828470097854734, 0.8212191631319, 0.842324016243219,
0.882067339960486, 0.872661964339204]
New Column( "Component 2",
Numeric,
"Continuous",
Set Selected,
Set Values(
[0.116772082395202, 0.140967620703167, 0.125925316195233,
0.0770373142695993, 0.113037678561007]
New Column( "Component 3",
Numeric,
"Continuous",
Set Selected,
Set Values(
[0.0547578197500645, 0.0378132161649326, 0.0317506675615479,
0.0408953457699151, 0.0143003570997886]
dtStack = dt << Stack(
columns( :Component 1, :Component 2, :Component 3 ),
Source Label Column( "Label" ),
Stacked Data Column( "Data" )
dtStack << Graph Builder(
Size( 534, 454 ),
Show Control Panel( 0 ),
Variables(
X( :Label ),
X( :Sample, Position( 1 ) ),
Y( :Data ),
Overlay( :Sample )
Elements( Bar( X( 1 ), X( 2 ), Y, Legend( 33 ) ) ),
Dispatch(
"Label",
ScaleBox,
{Label Row( 1, {Automatic Tick Marks( 0 ), Show Major Labels( 0 )} )}
Dispatch(
"Graph Builder",
FrameBox,
{DispatchSeg( BarSeg( 1 ), Set Width Proportion( 1 ) )}
