aaronjiang
Cluster large data sets into 9 points per cluster and calculate standard deviation/mean
I have a large data sets and would like to cluster the data into 9 points per cluster that form a square. Afterwards i would like to calculate mean and standard deviation for each 9-point cluster. Is there built-in function in JMP for that? Or do I need a script?
phil_kay
Re: Cluster large data sets into 9 points per cluster and calculate standard deviation/mean
I am not sure what you mean by "that form a square". How many variables do you want to use for clustering?
Also, how large is the dataset?
