ptkguy
Close Journal Window
I am running JMP 8.0.2.2 on Windows XP. I am trying to close a journal window without displaying the 'Save Changes to the Journal...' dialog.
My current script is simply:
current journal()<current journal()<
Sometimes the save dialog just gives me a log entry, but more often the dialog box interrupts the script until the user responds.
pmroz
Re: Close Journal Window
I make the journals readonly, so that users can't accidentally overwrite the existing journal file.
The other approach I'm using in JMP 9.0.0 is addins with menu customization (instead of journals). Users really appreciate the menus - they don't have to search for the journal file to run an application.
ptkguy
I should have been more clear. I am generating multiple reports and appending them to journals. I then save the Journals as .jrn and .html files for users to view. The reports get generated on a daily basis, but currently I have to manually intervene to allow the script to save all the journals.
ms
Super User ms
> current journal()<> current journal()<>
I don't know if it's the first or second line that invokes the Windows save dialog, but what happens if you use <
ptkguy
The '<
Article Labels
