BookmarkSubscribe
vkessler
Community Trekker
Close Explore Outliers Object
I want to automatically clean my data using the "Explore Outliers" feature in JMP 13.
This works fine with the exception that there is still an open window after the following code:
	outliers = Explore Outliers(
		Y( :foo ),
		Where( :Name( "foo" ) == "bar" )
	outliers << Robust Fit Outliers;
	outliers << K Sigma( 4 );
	outliers << Exclude Rows( :foo );
	outliers << Close;
Is there a way to also close the window I´m left with?
Here is the window:
Re: Close Explore Outliers Object
use
outliers << Close window;
use
vkessler
Community Trekker
Thanks! That made the trick!
