FR60
Clear single cells
Hi I selected with red color some cell into a JMP table. Now I would like to clear all the cells with only one command. Can you help me?
Re: Clear single cells
Once the cells are selected, then select Edit > Clear.
FR60
Ciao Mark thanks for your reply.
Whene I have the cell colored the clear option under Edit is not selectable....
Felice
JMP does not let you select an irregular pattern as you have illustrated.  When you select cells from different columns, the cells for all selected rows will be selected.  However, you could do what you want in 2 clear operations.  Select the cells you want to clear for one column, right click and select clear, and then repeat the selections for the second column.
Finally, there is not a way to clear cells based upon cells being colored, vs. not colored.
FR60
Hi
I have the solution.
By selecting explore outliers and then robust fit outliers (or Quantile range outliers) I can choose the option color cells and then "Add to missing value codes". In this way JMP will ignore those single values.
Rgds.  Felice
