djhanson
Clear Column Contents Message
Besides looping thru a column's rows, does JSL happen to have a column message to clear/delete a column's contents?  just curious... thx, dj
ms
Super User (Alumni) ms
Re: Clear Column Contents Message
No dedicated "delete content" command that I am aware of. However <<Set Each Value() can be used as such a message. Another option is Main Menu("Delete"), but I do not recommend that unless one has 100% control over what is selected in the current data table (it may in some circumstances even delete the code in the script editor rather than the column content).
// A simple way to do it
Column( "age" ) << set each value( Empty() );
Column( "name" ) << set each value( Empty() );
// Another, more risky, way to do it
dt << select all rows;
Column( "sex" ) << setselected( 1 );
Main Menu( "Delete" );
ms
