AT
AT
Level V
Choose two columns from two different tables
I like to choose two columns from two different tables (data table dt1, and dt2) and I ran the below script and it lists the varaibles names for data table dt1 only. Is there an issue with my script? I appreciate your help.
xvar = .;
yvar = .;
win = New Window( "Choose Two More Variables for Matching",
<<Modal,
<<On Validate(
// require the user to select two variables before clicking OK
Show( xvar, yvar );
If( Is Missing( xvar ) | Is Missing( yvar ),
0, // if xvar or yvar are missing, do nothing when OK is clicked
1
Text Box( " Select two numeric columns. " ),
H List Box(
Text Box( " Choose First " ),
x = Col List Box(
dt1, // data table reference
all, // display all columns from the data table
xvar = (x << Get Selected)[1];
// get the name of the selected column before the window closes
Show( xvar );
Text Box( "Choose Second" ),
y = Col List Box(
dt2,
all,
yvar = (y << Get Selected)[1];
Show( yvar );
gzmorgan0
Re: Choose two columns from two different tables
The Scripting Index and teh JSL Syntax reference shows the proper syntax to be
Col List Box(<Data Table ("name" )>, <"all"|"character"|"numeric">, ....). See a modification of your script, using the Data Table( ) syntax seems to work. However, you cannot use these in one analysis or platform call unless the columns are in the same table or a the two tables are virtually linked.
dt1 = Open("$sample_data/big class.jmp");
dt2 = open("$sample_data/big class families.jmp");
xvar = .;
yvar = .;
	<<Modal,
	<<On Validate(
		 Show( xvar, yvar );
			0
			1
	H List Box(
		x = Col List Box(
			Data Table(dt1 << get name), // data table reference
			Show( xvar );
		y = Col List Box(
			Data Table(dt2<<get name),
			all,
			Show( yvar );
AT
AT
Level V
Thanks. It works.
