BookmarkSubscribeRSS Feed
Checking values in columns against column limits
Hi Guys,
I have multiple columns (tests) and rows (serial numbers) in my data table and I want to check each cell value for every row with the limits of that column. I want to report back the row value (serial number) and the test that has failed the limits for that column. What is the easiest way to do this? I had come across something of the following nature but cannot find any documentation (I looked in the JMP scripting guide) regarding this.
Re: Checking values in columns against column limits
Ok modified the script to get the column names right.
I already have the values stored in a matrix. Maybe I can use them to extract the column names? Anybody has any ideas?
