WendyLou315
Check Box question with subgroups with select all of each subgroup fails
Hello Folks!  I have generated a user window to select any from 2 series of charts.  The series are "Only curves" or "Curves and data points".  My issue is that I also need to have a "Select all Curves" and "Select all Curves and Points" options.  The two "Select All" check boxes work great. However, if I select anything on the Curve chart side and DO NOT select the "Select all Curves and Points" check box (even to select and deselect), rather I select one or more individually, the selected Curve and Data Point charts are not entered into the list of charts to produce.  What am I doing wrong?  Code included.  Thank you all in advance for looking at my issue!
//Generate charts for selected data
GetCharts = {};
GetDPCharts = {};
//Window for user to select which charts to be generated
WhatCharts = New Window( "Select Curve Charts to Generate", << Modal,
	<< On open( WhatCharts << Window Size( 200, 100 ) ),
	H List Box(
	//All charts wtih ONLY curves
	cbAllCharts = Check Box( {"By Condition", "By Cond No", "By Sample", "Average by Condition"} ),
	Spacer Box( Size( 10, 0 ) ),
	//Charts with Data Points AND Curves
	cbAllDPCharts = Check Box( {"By Condition w/ Data Points", "By Cond No w/ Data Points", "By Sample w/ Data Points", "Average by Condition w/ Data Points"})
	//Allow the user to select all charts
	H List Box(
	cbAll = Check Box( " ",
		<< Set Function(
			Function( {this},
				cbAllCharts << Set All( this << Get, run script( 1 ) )
	Text Box( "Select All Curve Plots" ),
	Spacer Box( Size( 9, 0 ) ),
	cbAll2 = Check Box( " ",
		<< Set Function(
			Function( {this},
				cbAllDPCharts << Set All( this << Get, run script( 1 ) )
	Text Box( "Select all Points and Curve Plots" ),
	H Center Box( Button Box( "OK", GetChkBoxes )
//Place all selections into one list
if( N Items( GetDPCharts ) > 0,
	For( i = 1, i<= N Items( GetDPCharts ), i++,
		Insert Into( GetCharts, GetDPCharts[i] )
//Expressions
GetChkBoxes = Expr(
	GetCharts = cbAllCharts << Get Selected;
	GetDPCharts = cbAllDPCharts << Get Selected;
Print( GetCharts, GetDPCharts );
david707
Re: Check Box question with subgroups with select all of each subgroup fails
Give each checkbox it's own function and make sure all functions have different names:
//Generate charts for selected databutton
GetCharts = {};
GetDPCharts = {};
WhatCharts = New Window( "Select Curve Charts to Generate", << Modal, << Return Result,
	//<< On open( WhatCharts << Window Size( 200, 100 ) ),
	H List Box(
	cbAllCharts = Check Box( {"By Condition", "By Cond No", "By Sample", "Average by Condition"},
		<<SetFunction( Function( {f1}, GetCharts = cbAllCharts << get selected ) ) ),
	cbAllDPCharts = Check Box( {"By Condition w/ Data Points", "By Cond No w/ Data Points", "By Sample w/ Data Points", "Average by Condition w/ Data Points"},
		<<SetFunction( Function( {f2}, GetDPCharts = cbAllDPCharts << get selected ) ) ),
	H List Box(
		<< Set Function(
			Function( {f3},
				cbAllCharts << Set All( f3 << Get, run script( 1 ) )
		<< Set Function(
			Function( {f4},
				cbAllDPCharts << Set All( f4 << Get, run script( 1 ) )
	H List Box( Button Box( "OK" ) )
david707
GetCharts = {};
GetDPCharts = {};
	H List Box(
	H List Box(
		<< Set Function(
			Function( {f3},
		<< Set Function(
			Function( {f4},
WendyLou315
AWESOME! Thank you for the tutorial and furthering my JSL understanding and toolbox!
