JerryFish
Changing marker type, size, and color in JSL's Drag Marker
I found this example script online that uses JSL's Drag Marker command to create a graph and then allow me to drag points around.
The points are always small black dots.
I haven't found a way to change the marker type, size, or color in the Drag Marker command.  Is there any way to do it?  Thanks!
using JMP 19.0
New Window( "Example",
	exx = [11 33 77];
	exy = [88 22 44];,
	gb=Graph Box(
		Drag Marker(exx, exy);
hogi
Level XIII
Re: Changing marker type, size, and color in JSL's Drag Marker
There is a wish from 2023 to add a setting for the color (and shape):
Drag Markers: option to adjust the color (and shape?)
With only three Kudos, the idea still has a long way to go. Please vote!
For most of the JMP users, the current behavior of the drag markers  fine.
They don't use drag markers.
