dn610
Changing Date Format from Nominal to Numerical Data
Hi, I would like to change the below date field, which is a nominal field, to m/d/y format in jsl. Please help.
Re: Changing Date Format from Nominal to Numerical Data
Create a new numeric column
In the Col Info dialog window, set the format to m/d/y
Set a formula for the column of
Informat( :Day of Process Date, "Format Pattern", "<Month> <D>,  <YYYY>" )
Here is a script that when run creates the above example data table
New Table( "Format Pattern",
	Add Rows( 1 ),
	New Column( "Day of Process Date",
		Character,
		"Nominal",
		Set Values( {"November 8, 2024"} )
	New Column( "New date",
		Numeric,
		"Nominal",
		Format( "m/d/y", 12 ),
		Input Format( "m/d/y" ),
		Formula(
			Informat(
				"Format Pattern",
Format Pattern was released in JMP 16 so that is why the formula does not work.  Here is a formula that works in JMP 15
If( Row() == 1,
	monthList = {"January", "February", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December"
Date MDY(
	Contains( monthList, Word( 1, :Day of Process Date, ", " ) ),
	Num( Word( 2, :Day of Process Date, ", " ) ),
	Num( Word( 3, :Day of Process Date, ", " ) )
6 REPLIES 6
	Add Rows( 1 ),
		Character,
		"Nominal",
		Numeric,
		"Nominal",
		Formula(
			Informat(
				"Format Pattern",
dn610
When I tried to run the sample script above, the New date column doesn't populate for me. I also tried doing adding the formula manually, and it still doesn't work.
What version of JMP are you using and on what operating system.
I ran the code on both JMPPro 18 and JMPPro 16 on a Windows 11 and it ran without an issue.
Do you have any messages in the log?
dn610
No error message. I have JMP 15 and windows 10.
If( Row() == 1,
Date MDY(
dn610
Thank you!
