anthony
Changing DT values using JSL
Hi, I'm fairly new to SAS software in general, and even more unfamiliar with JSL. I'm making very simple automation scripts and am running into issues.
I would like to (In a data table of 600,000+ entries)
1) Select certain rows based on specific criteria
ex: dt<< Select Where(age>15)
2) Manipulate a specific column based on that row selection
ex: For those rows with age>15 change the column "Eleigible" from "No" to "Yes"
I do not know how to code this second part, I'd imagine it's pretty simple. I've read the JMP basic scripting tutorial, but I can't seem to figure out how to execute this simple operation.
Any help would be appreciated.
-Anthony
pmroz
It's not too hard.  Here's an example using Big Class:
dt = open("$sample_data\Big Class.jmp");
one_set_rows = dt << get rows where(:sex == "F");
column(dt, "name")[one_set_rows] = "Female";
Basically you use GET ROWS WHERE to get a matrix of row numbers that match a certain condition.  The last line allows you to put one value in all rows found that match the condition.
pmroz
MTOF
Re: Changing DT values using JSL
Or - if you have to make a new column anyway:
dt<<new column("Eligible",character,formula(If(:Age < 15, "no", :Age >= 15, "yes")));
BR, Marianne
Article Labels
