BookmarkSubscribeRSS Feed
Change the x axis
I begin with jump and i have a question about the graph builder.
I have 3 columns :
  1. Chr
  2. Position
  3. M1AllMP
The X axis is divided firstly in Chr and secondly with the position.
The "max" of the position is different between the different Chr.
The x axis "position" of Chr2 must be little than the Chr1.
But the x axis is the same for the chr1 and chr2 and if i try to reduce x axix for chr2, it's reduce for the chr1. I want that the x axis of chr1 is independent of the x axis chr2.
I have this graph :
[Missing image]
Thanks
XanGregg
Jun 23, 2011
Solution
Re: Change the x axis
The axes will always be the same across groups to make the panels more comparable. For unlinked axes you can use separate variables. Use Tables > Split to split the Position column by Chr, keeping M1AIMP.
Here's my version using Big Class.jmp, after splitting heighy by sex, keeping weight.
[Missing image]
By the way, how did you make your picture? I'm curious about why some parts are transparent in yours but not in mine.
XanGregg
Jun 23, 2011
Solution
[Missing image]
Change the x axis
Thank you !!!
