BookmarkSubscribeRSS Feed
Ole
New Contributor
Jun 11, 2018
Change of numeric data format when summarizing tables in JMP14
Hi Everyone,
My issues is as follows:
- when I import a file using my script (simple "dt = open (direction/file.xls);" ) it works correctly and shows datetime in datetime format and the values in "Best" format
- when I summarize this table and set "Link to original data table( 0 )," the format of the numeric columns is changed. Datetime as well as the values are changed to fixed decimal, with Dec = 0.
This messes my script up as I'm looking at numbers with 4 decimals and need them to stay in the original format.
In JMP13 (where I wrote the script) the numeric format is transfered from the original table without any changes.
Is this a scripting issue or a bug in JMP14?
Thanks
Ole
Jun 22, 2012
Solution
Re: Change of numeric data format when summarizing tables in JMP14
Using JMP 14.2, and the JMP Sample data table, Aircraft Incidents, I summarized the 2 columns, Event Date, and Number of Engines........they have a date format and a best format, respectively. The resulting summarized data table retained the same formats.
Jun 22, 2012
Solution
Ole
New Contributor
Jun 11, 2018
Updateing to JMP 14.2 fixed the issue. Thanks for the hint.
Ole
