mallen810
Change column name within previous script
I am trying to change column names from data that I have already brought in from a database. The columns currently are labeled with numbers and I would like to give them names. Below is the current data table script. Thanks in advance for your help.
Data Table( "100 conveyor data112018.jmp" ) <<
Summary(
Group( :Date, :Time ),
Mean( :Name( "1" )),
Mean( :Name( "6" ) ),
Mean( :Name( "19" ) ),
Mean( :Name( "20" ) ),
Freq( "None" ),
Weight( "None" ))
Re: Change column name within previous script
Here are a couple of variations on the question you are asking
dt = Data Table( "100 conveyor data112018.jmp" );
dt:Name( "1" ) << set name( "New Name 1" );
dt:Name( "6" ) << set name( "New Name 2" );
dt:Name( "19" ) << set name( "New Name 3" );
dt:Name( "20" ) << set name( "New Name 4" );
dt2 = dt << Summary(
	Mean( :Name( "New Name 1" ) ),
	Mean( :Name( "New Name 2" ) ),
	Mean( :Name( "New Name 3" ) ),
	Mean( :Name( "New Name 4" ) ),
	Freq( "None" ),
	Weight( "None" )
// or
dt2 = Data Table( "100 conveyor data112018.jmp" ) <<
Summary(
Freq( "None" ),
Weight( "None" ));
dt2:Name("Mean(1)") << set name( "New Name 1" );
dt2:Name("Mean(6)") << set name( "New Name 2" );
dt2:Name("Mean(19)") << set name( "New Name 3" );
dt2:Name("Mean(20)") << set name( "New Name 4" );
I suggest that you spend some time reading the Scripting Guide, which will give you all of the background on the language structures and the syntax on how to deal with them.
     Help==>Books==>Scripting Guide
