BookmarkSubscribe
seburke89
Community Trekker
Change Graph Builder properties when using local data filter?
Hi all,
I'm writing a script for a graph that will become a part of another function. The graph has X2 on the X-axis and a group y variable Y. I know I can set the number of levels for Y directly in the script, but I also have a local data filter with the graph so that the user can look at the effect of X2 & y for different values of another variable X. For different values of this variable X, the number of levels of Y can change. Is there a way in the JSL script to change the number of levels of Y in the graph when a new option in the local data filter is selected? I've been trying to use a row state handler, but can't seem to find the right function call to change the number of levels in the graph. Thanks for your help! Sarah
g = Graph Builder(
    Variables( X( :X2), Group Y( :Y, Levels(10) ), Color( :Group ) ),
    Elements( Points( X, Legend( 5 ), Jitter( 0 ) ) )
ldf= g << Local Data Filter(Mode, Add Filter(columns(:X), Display( :X , Single Category Display )));
doSomethingWithSelection = Function({x},
    {Default Local},
    rows = ldf << get filtered rows;
    in = Column(dt, "Y") << get values;
    in = in[rows];
    numUniqueRows = nrow(getUniqueValues(in)); //separate function I wrote...
    //change/update number of levels of y in graph g using numUniqueRows
gbReport = g << Report;
rsh = gbReport[OutlineBox(1)] << MakeRowStateHandler(doSomethingWithSelection);
