Change Default Number of Grid Points in Profiler "Max for Each Grid Point"
The default number of grid points on locked parameters in Profiler is 5 for Profiler's "Maximize for Each Grid Point" operation. How do I change the number of grid points from 5 to some other value?
Thanks
mpb
Jun 23, 2011
The profiler lets you choose any number of levels less than 41. If you choose 41 or higher JMP appears to use only 5 levels when optimizing for each grid point. I don't know if this is intended behavior but if it is I would expect a warning message if I tried too large a number of levels.
Thanks!
