BookmarkSubscribeRSS Feed
Casting a "Calculated Field" into a platform role
Is it possible to select two or more columns in a formula and cast it into a role for a graph (or even analysis) platform?
Excel allows you to create a calculated field as formulas in Pivot Tables.
The method is to create a formula in the PivotTable report as a calculated field. This item will now be reflected in PivotChart reports. This is very useful in analyzing utility cost / unit of measure when you have data at different levels and have columns containing actual amount and actual quantity.
I have been unable to reproduce this functionality in JMP. Any ideas?
XanGregg
Re: Casting a "Calculated Field" into a platform role
The way to do this in JMP is to create a new column and give it a formula property (right-click on column name and choose "Formula") with the desired formula. Then use the new synthetic column in your analyses.
