zimmerj
Cannot save window to journal file
I have a script which creates a window and saves plots in a specific orientation.  When that is complete I attempt to save the window to a journal file as described in the JMP Scripting Guide.  However every time I attempt to do this the file is not created.  I can save the window to HTML without issue.  Here is the portion of the script I'm having trouble with:
MyWin = New Window( "Big Classy", vlb = V List Box());
For( i = 5, i <= 10, i++,
  vlb << append(
  H List Box(
  Eval( Eval Expr (VarPlot) ),
  Eval( Eval Expr (BVplot) )
MyWin << Save Journal("C:\Path\file.jrn");
Using
MyWin << Save HTML("C:\Users\jzimmerman\Desktop\BigClassy.html", PNG);
works just fine.  Does anyone know what I might be doing incorrectly?
