lwx228
Community Trekker
Re: Can this two-step formula be calculated in one step?
And jmp's [Index(Row()-1,Row()-1)] like excel's INDIRECT()
vince_faller
This is definitely not true.
Indirect in excel returns a valid cell reference from a string.  This has nothing to do with strings.
This is simply indexing a matrix.  Check out the JMP scripting guide for matrix subscripting
Vince Faller - Predictum
lwx228
Community Trekker
Yes, what I said above is not correct.
And I should have used JMP's :[Index(Row() -x,Row())] is a function commonly used to substitute excel's INDIRECT() formula
JMP's :[Index(Row() -x,Row())] can do a lot more.
It, like INDIRECT(), can compose numerous applications.
