lala
Level IX
Can JMP make such diagrams as excel does?
13.64,13.71,13.38,12.9,12.85,12.9,12.89,12.76,12.73,12.74,12.65,12.64,12.92,12.83,12.79,13.08,13.57,14.6,16.3,15.23,15.66,15.35,14.7,14.9,14.78,14.3,14.17,14.23,14.68,14.49,14.24,13.97,13.67,13.34,13.35,13.5,13.28,13.47,13.66,13.82,13.82,13.8,13.67,13.97,14.21,14.4,14.1,14.6,15.2,15.11
Thanks!
Re: Can JMP make such diagrams as excel does?
Hi Lala,
Are you trying to display a run chart of each row? You can do something similar in the new JMP 18 addition with the addition of improved header graphs - in the example below you can see it's displaying the row values for each column in row order. You can achieve this by right clicking > Chart Type > run chart.
lala
Level IX
Thank Ben!
Yes, I want each row to display the graph for that row, so it's compact.
dlehman1
I believe what you are wanting are called sparklines (invented by Edward Tufte).  If your data is in rows as you show, then you will want to transpose it so it is in columns.  While you can get the displays at the top of each column as Ben_Ingham shows, you can also produce these in Graph Builder by dragging each of the desired columns into the Y variable range and choosing the line graph (assuming these are in a time sequence - or if you have a specific time variable, put that in the X variable range if it isn't already sorted by time).
Not really something I would consider you should do with JMP, but you can do this but not directly from your data format.
Start
Transpose data
Stack
Create graph
and make it into data table
Join this back to your original data by matching rows
(you can make the graphs cleaner using JSL)
