mark_anawis
Can JMP be scripted without connecting to R to do Deep Learning?
We are investigating Deep Learning for predictive modeling to identify instrument subsystem failures using R and Python packages. Since Deep Learning is similar to neural nets, perhaps these can be used as the basis of a script to expand the number of layers. Deep Learning would be a good tool for future versions of JMP Pro.
Re: Can JMP be scripted without connecting to R to do Deep Learning?
It sounds like a great idea.
To insure that the JMP folks officially receive your suggestion, you need to send it directly to them, at
     support@jmp.com
Or post this into the JMP Wish List at the menu bar. Then others can Cudo it to make it more important.
