Subscribe Bookmark RSS Feed
Can I save output to a Second Journal While I'm Using the First Journal as My Presentation Tool?
DaveLee
Jun 11, 2014
I'm just wondering about this.  I will be giving a presentation where I will be using a JMP Journal as my main presentation vehicle.  I'd like to save output from the analyses to a second journal to show how easy it is to create a report, PowerPoint file, HTML, etc?  Right now, when I Ctrl-J the output goes to my active 'Presentation' journal.  Am I missing something here?  Thanks.
Dave
Craige_Hales
Mar 21, 2013
Solution
Try locking the presentation.  The next journal command will notice the lock and create a new journal.
Craige
louv
Jun 23, 2011
Hi David,
In order to do what you desire I believe that somehow you would need to include the data table in the new Journal so that you can keep the Journal where you want to save your work active. If you do this then it should work as you describe.
Craige_Hales
Mar 21, 2013
Solution
Craige
DaveLee
Jun 11, 2014
Thanks Craige! It worked perfectly.
Dave
