shrirams
Can I make Formula Depot invisible?
Hi - I am using Formula Depot as follows to run the NN model fit from table dt1 on a new table dt2:
nn = dt1 << Neural(
	Y( :Vg ),
	X( :log10Id ),
	Informative Missing( 0 ),
	Validation Method( "Holdback", 0.3333 ),
	Fit( NTanH( 3 ) ), Invisible
	fd1 = Formula Depot();
	nn << Publish Prediction Formula;
	fd1 << Run Scripts(Table(dt2), Formulas(1));
	fd1 << Close Window;
I would like to ideally run this with no windows opening up as this code runs inside a for loop. However, when I run the code, the Formula Depot window opens up.
I have tried:
fd1 = Formula Depot(Invisible);
and
fd1 = Formula Depot() << Invisible;
But, none of them work. Is there any suggestion?
shrirams
Re: Can I make Formula Depot invisible?
Hi Jim - thanks for the suggestion. At what point do you recommend putting in that code? If it is after
then the window still opens up momentarily before your suggested code snippet suppresses it. Is there some way to not have the Formula Depot window pop up in the first place?
shrirams
I think I found the solution using a different forum post.
fd1 = Formula Depot() << Show Window(0);
suppresses the window.
Here is my suggestion is:
window(dt1<<get name || " - Formula Depot")<<visibility("hidden")<<minimize window;
shrirams
shrirams
