B_McCarty
Can I do calculations of statistics in a Tabulate Table?
Good Day,
I want to show the difference between two means in my tabulate table.
I would like to have JMP do the math and report the difference of 0.11 in this table, perhaps as a new row or as a new table in this window. I have redacted names of rows and columns that don't matter for my question.
Thanks,
Blake
pmroz
Re: Can I do calculations of statistics in a Tabulate Table?
You'll most likely need to save the tabulation as a data table and do your calculations with that.  Here's some JSL that will get you started:
dt = open("$sample_data\Big Class.jmp");
dtab = dt << Tabulate(
	Show Control Panel( 0 ),
	Add Table(
		Column Table( Analysis Columns( :height ), Statistics( Mean ) ),
		Row Table( Grouping Columns( :sex ) )
	), invisible
mdt = dtab << Make Into Data Table;
dtab << close window(1);
mdt << add rows(1);
column(mdt, "sex")[3]          = "Diff";
column(mdt, "Mean(height)")[3] = column(mdt, "Mean(height)")[1] - column(mdt, "Mean(height)")[2];
