SpannerHead
Can I copy the embedded scripts from one table to another?
If I have a parent table with many scripts embedded.  Can I copy those easily to a summary table or transposed table automatically using JSL?
Slán
SpannerHead
Re: Can I copy the embedded scripts from one table to another?
Yes
dt1 = open("$SAMPLE_DATA/Big Class.jmp");
dt2 = open("$SAMPLE_DATA/Big Class Families.jmp");
dt2 << Delete Scripts(dt2 << Get Table Script Names);
For Each({sname}, dt1 << Get Table Script Names,
	s = dt1 << Get Script(sname);
	Eval(EvalExpr(dt2 << New Script(sname,
		Expr(NameExpr(s))
Write();
Yes
		Expr(NameExpr(s))
Write();
SpannerHead
Jarmo
Brilliant!  You should see the script this replaced!
Slán
SpannerHead
This has been a repeated topic in the Discussion Group.  A simple search would have provided the answer to you faster and more efficiently that opening a new discussion and waiting for someone to respond.
SpannerHead
I apologise profusely, it won't happen again!
Slán
SpannerHead
