BookmarkSubscribeRSS Feed
statpharmer
Community Trekker
Apr 14, 2014
Can I Create and Optimized Design for Order of Addition Experiments?
There are 6 materials used to create a liquid solution that is the subject of experimentation. The amounts of each material are fixed; however, we know that the order in which each is introduced can have an effect on the responses. Is there a way to design a set of experiments that can test the order of addition without having to run a full factorial?
Rob Lievense
RobertMee
Community Member
Feb 28, 2017
Re: Can I Create and Optimized Design for Order of Addition Experiments?
Joe Voelkel spoke on this topic at the 2016 QPRC.  He used Proc Optex to select a D-efficient subset of sequences, based on a specified (e.g., first-order) model.   Contact me (rmee@utk.edu) for more ideas.
jfyang
Community Trekker
May 1, 2017
I can give you a suggestion on the best order of addition according to my method. Could you share your data with me?
