Can I Build a DOE with This existing data???
Below are the Responds...
A - Min
B - Target
C - Min
D - Min
Factors:
F1 - 2 level (Con)
F2 - 3 level (Con)
F3 - 3 level (Con)
F4 - 3 level (Con)
F5 - 2 level (Cat)
and the data i have is...
A B C D F1 F2 F3 F4 F5
350 66 10.6 21.38 1150 940 5 1012 6
550 84 9.59 20.27 1130 920 5 1030 6
476 64 10.06 23.95 1130 920 5 1012 6
570 55 9.92 20 1130 920 5 1040 6
612 93 9.33 21 1130 910 25 1030 4
520 21 9.76 19 1130 910 15 1030 4
Can i build the DOE with this existing data? Thanks
statman
Re: Can I Build a DOE with This existing data???
Build a DOE with the data???? The question is what can you do with the data. It is certainly not a factorial design and there is no balance. My suggestion is to do some graphical plots and see if you see anything. You have provided no information regarding whether the data is of any practical importance (did the response change enough to matter?). Some simple scatter diagrams may provide some insight. It is ALWAYS best to plan an experiment.
