lhasen
Community Member
Calculate Effect Base Size?
I'm using JMP v13. Does it have the ability to calculate effective base size (when weighting data) and stat test based on those Ns? If JMP does this, is it eabled the same way regardless of platform? If not, I'm specifically interested in the categorical platform. Thanks!
