Kristin
CUSUM chart with subgroup variable
I'm trying to understand how the cusum chart is calculated usind a subgroup variable X where some X values are present multiple times. For example, I have 3-5 measurements per day and the cusum chart should be grouped by day. Since it says in the JMP help regarding X "If a value of this column is present more than once, the average response at each X value is plotted on the CUSUM chart.", I thought that the daily averages of Y are calculated and then the cusum calculation is done with the aggregated data. For T and sigma this gives the same results as the cusum calculation with the original data and day as X variable, but the chart looks completely different. Can you please give me an explanation how the calculation is done? Thank you.
Phil_Kay
Re: CUSUM chart with subgroup variable
Can you share an illustrative data example as a .jmp file? That will help the community to help you.
Thanks,
Phil
Kristin
The file CUSUM_example contains the raw data. There are several measurements for each MEAS_STARTDATE. The other file contains the average number of counts grouped by MEAS_STARTDATE (daily averages). I thought that the cusum charts should be equal for both cases, but they look completely different. Can anybody explain why? Thank you.
ian_jmp
Level X
In conjunction with the documentation for the platform, the script below should help you to understand how it works. Do 'File > New > New Script' cut and paste the code below into the resulting window, then do 'Edit > Run Script'):
NamesDefaultToHere(1);
ng = 10;		// Number of groups
ns = 5;			// Size of group
// Make some data
sVals = SortAscending(Repeat((1::ng)`, ns));
cVals = J(ng*ns, 1, RandomInteger(0, 20));
dt1 = NewTable("Raw Data",
		NewColumn("Group", Numeric, Ordinal, Values(sVals)),
		NewColumn("Count", Numeric, Continuous, Values(cVals))
// Do the Cusum Control Chart (note the 'Data Units' option)
dt1 << CUSUM Control Chart(Y( :Count ), X( :Group ), Show Center Line( 0 ), Data Units( 1 ));
// Agregate the data (use the 'sum' not the 'mean'!)
dt2 = dt1 << Summary(Group( :Group ), Sum( :Count ));
// Do the Cusum Control Chart with the agregated data (note the 'Data Units' option)
dt2 << CUSUM Control Chart( Y( :"Sum(Count)"n ), Show Center Line( 0 ), Data Units( 1 ));
Kristin
Hi Ian,
thanks for the script. I see that it's working with Data Unit option set to 1. Apart from scaling I get the same result for the sum or the mean if I dont't use data units. That's what I expected. However, the chart for the raw data looks different when setting data units to 0 (see attached image). Can you explain this?
This is my script:
// Make some data
dt1 << CUSUM Control Chart(Y( :Count ), X( :Group ), Show Center Line( 0 ), Data Units( 0 ));
dt2 = dt1 << Summary(Group( :Group ), Mean( :Count ));
dt2 << CUSUM Control Chart( Y( :"Mean(Count)"n ), Show Center Line( 0 ), Data Units( 1 ));
dt2 << CUSUM Control Chart( Y( :"Mean(Count)"n ), Show Center Line( 0 ), Data Units( 0 ));
dt3 = dt1 << Summary(Group( :Group ), Sum( :Count ));
dt3 << CUSUM Control Chart( Y( :"Sum(Count)"n ), Show Center Line( 0 ), Data Units( 1 ));
dt3 << CUSUM Control Chart( Y( :"Sum(Count)"n ), Show Center Line( 0 ), Data Units( 0 ));
